MB Recaster doesn't remember the "Capture Card" selection after reboot
  • bootika
20 Sep 2018 21:12 #86055 par bootika
Hello, I have this issue that after rebooting, MB Recaster doesn't remember the "Capture Card" selection. It displays nothing in the dropdown and the radio station broadcasts silence, because of no audio input. I have to manually re-select the audio card in order to start playing..
Thing is, I just had three hours of silence on my station because of an unexpected reboot (windows updates install). Can I do something about this issue?
Thank you,
20 Sep 2018 22:23 #86056 par MB RADIO
Unfortunately the Windows major updates change the index number of audio cards, let's say you're currently using the audio card input number 21 after the reboot the 21 is null and your input card has changed to 25. There is no way for MB RECASTER to avoid or predict this situation (you have to set again the audio cards on all audio programs). Let's hope Microsoft will no more change the audio index in the future.
Temps de génération de la page : 0.039 secondes
