MB Live
  • teutoradio
02 Sep 2018 23:15 #85878 par teutoradio
MB Live a été créé par teutoradio
I download the latest MBLive 1.61, but the problem is now, that we use in MB Radio the split on air channel 1-2 and 3-4. If we connect to the main studio, only channel 1-2 can be heard, so in automatic mode only every second title. Is there a way, to hear in MB Live all audio channel?
02 Sep 2018 23:20 #85879 par MB RADIO
Réponse de MB RADIO sur le sujet MB Live
I dont think this has nothing to do with MB LIVE. Probably you are using the Multiplayer option in MB STUDIO? If so, it's normal that audio play on different channels. Disable the multiplayer when you use MB LIVE.
  • teutoradio
02 Sep 2018 23:26 #85880 par teutoradio
Réponse de teutoradio sur le sujet MB Live
Yes we use the Multiplayer option in MB Studio. Is there a way to disable it automatic when I connect with MB Live? Because we use it in live mode or can it be activate and disabled via MB Live ?
02 Sep 2018 23:30 #85881 par MB RADIO
There is no way but eventualy you can use the Instant Players output for MB LIVE.
and choose the output that you want for Instant Players
  • teutoradio
04 Sep 2018 20:15 #85908 par teutoradio
Sorry I don't understand. Why should I use the Instant Player output? I need to hear both channel 1+2 and 3+4 from the on-air list.
  • teutoradio
04 Sep 2018 21:42 #85909 par teutoradio
Réponse de teutoradio sur le sujet MB Live 1.61
Is it also possible to play and stop the songs in the playlist via MB Live? For example I like to talk live between two song ( manual play )
05 Sep 2018 19:02 #85913 par MB RADIO
teutoradio écrit: Sorry I don't understand. Why should I use the Instant Player output? I need to hear both channel 1+2 and 3+4 from the on-air list.
It was only a suggestion that maybe could be good for you because there is no way to play something on all channels when MultiPlayer option is enabled.
05 Sep 2018 19:03 #85914 par MB RADIO
Réponse de MB RADIO sur le sujet MB Live 1.61
teutoradio écrit: Is it also possible to play and stop the songs in the playlist via MB Live? For example I like to talk live between two song ( manual play )
Yes, insert a DELAY event between the 2 songs, this will stop the automation until you click NEXT
  • teutoradio
05 Sep 2018 19:11 #85916 par teutoradio
When I press in MB Live right mouse, i see only Remove, Move and Cancel, no insert
05 Sep 2018 19:23 #85917 par MB RADIO
See the guide here: www.mbradio.it/en/help/531-mb-live-commands (it's a double left click as explained)
