MB Studio search issue
20 Jui 2018 14:09 #85485 par lebaud
MB Studio search issue a été créé par lebaud
Hi Maurizio,
In the past, MB Studio was able to find back songs or files when stored in the registered folders (into the configuration) but without the need of having them encoded in the song database.
It seems that this is not possible anymore since one of the last version (I would say 8.60.6.1), we need to add all the songs or files into the database first.
Is there any possiblity to have this fixed ?
Many thanks,
Kind regards,
Bernard.
21 Jui 2018 00:37 - 21 Jui 2018 00:38 #85489 par MB RADIO
Réponse de MB RADIO sur le sujet MB Studio search issue
You can actually play any audio file without the need to add it to the songs archive.
Simply click File to play any audio file on your computer or use the following to play a random file from a folder www.mbradio.it/en/help/331-event-random-file-from-a-folder
What kind of problem are you having?
21 Jui 2018 01:23 #85490 par lebaud
Réponse de lebaud sur le sujet MB Studio search issue
Hi Maurizio,
Yes, for sure I know this functionality :-)
Let me try to explain our issue again...
We are using different instances of MB studio in order to prepare some playlists about specific programs even if we are not connected to the master PC (so remotely). These different instances are not synchronized with the master. (stand alone) but have their own archive, so we can tag the songs and prepare the sessions.
Then we extract and copy these prepared playlists in our primary MB studio PC and put the concerned songs in a folder mapped into MB studio configuration. (known by the primary MB studio)
We don't want to have these tagged files added to the master archive because they are too much specific, we don't want to 'polute' our master archive.
In the past, MB Studio was able to find his way to these files, even if they were not added into his archive.
It seems that this opportunity doesn't exist anymore.
... so we use the workaround of adding 'file', but then we loose the tag infos.
If it's too complicated to understand, just forget this topic ;-)
Many thanks for your precious help.
Kind regards,
Bernard.
21 Jui 2018 10:16 #85493 par MB RADIO
MB STUDIO can find files in the playlist, it will scan the list of folders (Configuration\folder) for the same filename, so this should still work if your remote station add a file to the playlist. But if the remote station add a song from the archive the same song must be present also in your archive. If you have any problem with this please load a problematic playlist and fill a report (Menu Send Debug) and i will take a look
