Teasers
  • paul03034
23 Avr 2018 12:34 - 23 Avr 2018 12:36 #85037 par paul03034
Teasers a été créé par paul03034
Hi Maurizio,
In your example from previous post of teasing next hour www.mbradio.it/en/forum3/26-english-inte...6-music-of-next-hour[/url]
I suppose there is not a way to have the refrain/teaser random choice of how many you wish to tease?
Example:
In using your method/example of programming teasers in above post let's say there are 15 songs in a playlist and I wish to tease 5 of the 15 songs it will always tease the first 5 songs as to doing a random tease where it randomly picks 5 songs of the 15 songs to tease.
Or is there a way to get it not to do each song in a row, where it skips maybe the first two songs and does 3, 5, 8, etc.? Basically you pick a pick order of which ones to tease 3, 5, 8, 10, 15?
I can dream?
Next is there is a checkbox and time in setup for teasers and then the event with a teaser duration. The teaser duration in event has no effect on the length as it is overridden by the setting time. If I choose to uncheck allow teaser box in the setup I actually got the event time to work once and after that it skips all refrain/teasers in list. It would be nice to control length of at least first one as I was trying to use it as a background as Voice over is done on first teaser and I needed longer tease play than the others to do a VO over.
Thank you!
26 Avr 2018 12:43 #85048 par MB RADIO
Réponse de MB RADIO sur le sujet Teasers
paul03034 écrit: Hi Maurizio,
Unfortunately there is no way. And it's too late to add that option for the new version, so maybe i will add it sometime in the future.
11 Nov 2019 20:31 #88728 par radioansiaes
Réponse de radioansiaes sur le sujet Teasers
try this. it works for me
