MB Recaster Not Updating Listener Count
  • DJboutit
27 Mar 2018 20:30 - 27 Mar 2018 22:02 #84882 par DJboutit
MB Recaster Not Updating Listener Count a été créé par DJboutit
I am having a problem with MB Recaster it iwill not show current listener count it always stays at 0. Is there a trick to get to Recaster to correctly show current listener count that I might not be doing??
28 Mar 2018 09:34 #84883 par MB RADIO
Réponse de MB RADIO sur le sujet MB Recaster Not Updating Listener Count
what version are you using? The latest 4.4?
  • DJboutit
28 Mar 2018 19:08 #84885 par DJboutit
Réponse de DJboutit sur le sujet MB Recaster Not Updating Listener Count
Version 3.9.3 I am running it on Windows XP.
29 Mar 2018 10:07 #84886 par MB RADIO
If your stream server is shoutcast version 2 you must enter 2 password: the stream source password and the administrator passowrd. If administrator password is missing or wrong the stats could not be downloaded. See here: www.mbradio.it/en/help/322-webcast-how-to-activate-an-encoder
Also some free servers do not allow external encoders to download the stats so it could also be a server limit.
  • DJboutit
29 Mar 2018 10:56 #84888 par DJboutit
Server is v2 I only see a slot for user and a slot for password I do not see a slot for admin what is up??
29 Mar 2018 11:00 #84889 par MB RADIO
I see you are right, unfortunately 3.9.3 is too old version and do not support 2 passwords system. Following versions do not support Windows XP so im sorry but i don't have a solution for you until you are on Windows XP
  • DJboutit
29 Mar 2018 11:06 #84890 par DJboutit
So why even have a listener count on the older versions if its always stays at 0??
29 Mar 2018 11:43 #84893 par MB RADIO
The shoutcast v2 protocol has been changed after the release of MB RECASTER 3.9.3 so that old version do not get stats correctly form the newest shoutcast v2 servers but still work with older shoutcast v2 servers as well shoutcast v1 and icecast
