Weather announcements
  • paul03034
10 Aoû 2017 15:35 #83776 par paul03034
Weather announcements a été créé par paul03034
Is there a way to use announcer voice like in time to do the key weather words?
I use text to speech now, but wish a more natural sound using current weather function and announcer audio files.
recorded voice file() (Now here is the weather for the Q94 7 listener area. It is currently) %temp% (degrees)
I record temperature audio files for each degree and put in a weather folder and sub-folder temperature. Each sound file uses the name of the degree (3.mp3) would be for 3 degrees and would be pulled from folder for variable %temp%.
Maybe build a minilist weather to do this and each line is audio file
weatheropen.mp3
weathertemp.mp3
%temp%
weather close.mp3
or text file that lists all the audio files
weatheropen.mp3, weathertemp.mp3, %temp%, weatherclose.mp3
Just a thought if possible down road if not available now.
There is a program/company that uses real voices and more information for weather than MB Studio does called unattendedweather located at www.unattendedweather.com in English
If you could make similar additional module/feature available for additional cost $$, it would be great! User would record all the key words and your program would paste it all together like the time or weather does now.
Thank you!
12 Aoû 2017 02:57 #83786 par MB RADIO
Réponse de MB RADIO sur le sujet Weather announcements
paul03034 écrit: Is there a way to use announcer voice like in time to do the key weather words?
weatheropen.mp3
weathertemp.mp3
%temp%
weather close.mp3
Yes you can, prepare your audio files like temp0.mp3 temp1.mp3 temp2.mp3 etc etc as described here: www.mbradio.it/en/help/393-weather-configuration
  • paul03034
12 Aoû 2017 03:02 #83788 par paul03034
Réponse de paul03034 sur le sujet Weather announcements
Sorry I missed that part in the help files.
Thank you for pointing it out!
  • teutoradio
17 Aoû 2017 19:00 #83810 par teutoradio
Réponse de teutoradio sur le sujet Weather announcements
If we like to pre record human voice where to save all audio files and how should the mp3 files correctly named?
18 Aoû 2017 00:27 - 18 Aoû 2017 00:28 #83813 par MB RADIO
You can create your own folder and name the files as you want.
Ex: create a folder Weather, then for announcing the temperature you can create a series of files like temperature21.mp3 temperature22.mp3 etc etc
When you add the announce to the playlist only replace the value with corresponding wildcard ... ex: temperature%tempnow%.mp3
List of wildcards are here: www.mbradio.it/en/help/393-weather-configuration
