RDS Connection issue new with upgrades
  • paul03034
17 Juil 2017 22:11 #83551 par paul03034
RDS Connection issue new with upgrades a été créé par paul03034
Hi,
Over the past few updates I started to notice RDS connection issues. Now with the latest version I get a constant unable to connect com 1 and tried everything other than replacing RDS. I thought I had a cable or RDS issue, but then decided to download MagicRDS and it talks fine with the Pira 32 RDS. I have to assume this is an MB Studio issue as it can read and write to the unit..
Thank you!
17 Juil 2017 22:23 #83552 par MB RADIO
Réponse de MB RADIO sur le sujet RDS Connection issue new with upgrades
Here all is ok with PIRA RDS. Note that MB STUDIO communicate with pira at a speed of 2400 baud so if you changed this speed in MagicRDS MB STUDIO will be unable to communicate.
  • paul03034
19 Juil 2017 02:34 #83576 par paul03034
Réponse de paul03034 sur le sujet RDS Connection issue new with upgrades
I checked and RDS front panel shows baud rate 2400. I run Magic RDS 2400 and it reads and writes com 1. I keep magicRDS open which keeps open com 1 and try MB Studio and I get access denied as it should so I know it is trying com 1 port. Close Magic RDS and get error cannot connect to RDS.
I am installing software for a workstation and I will test with that to see if it talks to RDS unit. Very Strange as it worked and stopped after update for MB Studio and Microsoft also did update too at same time which maybe ?
My server is live now over the air broadcast, so I cannot play much with it and risk going off air. Right now I just have static RDS call sign and frequency and tag line for FM radios.
Thank you!
19 Juil 2017 11:25 #83582 par MB RADIO
Could you please send a report using menu Help \ Send debug ? Thanks
  • paul03034
19 Juil 2017 13:22 #83587 par paul03034
When I get to the mountain top later I will send it to you. Audio Server is there at transmitter site.
Thank you!
20 Juil 2017 00:21 #83609 par MB RADIO
Replace wsc32.dll with the one included in the zip below and tell me if the RDS communication works again or not.
  • paul03034
21 Juil 2017 02:30 #83640 par paul03034
The DLL file fixed the problem and RDS works fine now.
Thank you!
