Cueing points in mp3
  • teutoradio
07 Jui 2017 14:39 #82967 par teutoradio
Cueing points in mp3 a été créé par teutoradio
When I label an mp3 with MB Studio, the information ( Start, Intro, Teaser In, Teaser out, Outro and stop will be saved in the IDTag of the mp3 or in an extra database of MB Studio?
07 Jui 2017 15:05 - 07 Jui 2017 15:08 #82968 par MB RADIO
Réponse de MB RADIO sur le sujet Cueing points in mp3
both in the file and in the database.
if you loose the database you'll retrieve the data from the audio file
if you loose the tag you still have the data in the database (use menu' Edit \ Write Tag to rewrite tag to one, some or all songs)
  • teutoradio
07 Jui 2017 15:52 #82969 par teutoradio
Réponse de teutoradio sur le sujet Cueing points in mp3
Where can i find the database ( name of the file ) ?
07 Jui 2017 16:19 #82970 par MB RADIO
MBSongs.dat
  • teutoradio
08 Jui 2017 22:30 #82985 par teutoradio
OK thanks!
What kind of database do you use? We have the problem, that we send sometimes some mp3 from the our MB Radio Automation to a partner radio station who use another system but the cant read the cueing points.
Is there a way to convert?
08 Jui 2017 22:38 #82986 par MB RADIO
Unfortunately there is not a standard to exchange cue point between different applications
