MB Recaster record timing issue
  • paul03034
30 Mai 2017 15:10 - 30 Mai 2017 15:14 #82879 par paul03034
MB Recaster record timing issue a été créé par paul03034
Hello,
If I set a record for 8:00 it starts correctly, about a second before GOOD
I set a stop time of 8:59 and it continues recording to 8:59:59 which is 59 seconds past stop time Bad
It never seems to end at any stop time correctly.
I'm trying 9:30 - 9:58 to see if it goes past time and will update this post then.
30 Mai 2017 16:28 #82883 par MB RADIO
Réponse de MB RADIO sur le sujet MB Recaster record timing issue
the STOP time is inclusive, it means that the it will stop just at the end of minute 59. If you want to stop at 59:00 set the stop time at 58
  • paul03034
30 Mai 2017 16:59 - 30 Mai 2017 17:00 #82885 par paul03034
Réponse de paul03034 sur le sujet MB Recaster record timing issue
Just discovered that on :58 stop time.
Do you think you will ever be able to add the VOX function like in MB Spot to ReCaster Pro?
Thank You!
30 Mai 2017 17:19 - 30 Mai 2017 17:21 #82887 par MB RADIO
paul03034 écrit: Just discovered that on :58 stop time.
Yes i will add it in the near future
Les utilisateur(s) suivant ont remercié: paul03034
  • paul03034
01 Jui 2017 00:25 #82919 par paul03034
Excellent and Thank You!
