Minilist and audio file
  • paul03034
15 Mai 2017 02:24 #82616 par paul03034
Minilist and audio file a été créé par paul03034
Hello,
I noticed that when I create a minilist the one thing with an audio file is even after changing audio file from standard mix to no mix it always reverts back to standard mix after saving. Some audio files in a minilist I might want a standard mix and others no mix and I can never save it like it does in regular playlists.
Suggestion of what I am doing wrong or is this a bug?
Thank you!
15 Mai 2017 02:40 #82617 par MB RADIO
Réponse de MB RADIO sur le sujet Minilist and audio file
I was unable to reproduce the problem here, i set "No Mix" to 2 files in a minilist and the property is still there after saving or even when minilist is on air
  • paul03034
15 Mai 2017 02:43 - 15 Mai 2017 02:55 #82620 par paul03034
Réponse de paul03034 sur le sujet Minilist and audio file
This only applies to minilist
I go and it is standard mix
[attachment:1]minilist 1.jpg[/attachment
I change to no mix and apply
I look at properties and it says standard mix
  • paul03034
15 Mai 2017 13:45 #82629 par paul03034
Here is the minilist that was set to no mix in the playlist.
I do not see anything saying no mix where it is inserted from minilist.
Playlist is fine and stores settings.
15 Mai 2017 17:11 #82631 par MB RADIO
fixed on version 8.59.1.1
Les utilisateur(s) suivant ont remercié: paul03034
