Wave files being generated using text to speech
  • paul03034
04 Mai 2017 00:17 #82478 par paul03034
Hello,
I noticed in the MB Studio Directory that when I use a SAPI5 text to speech voice it generates a wave file for the text file that is played out as speech in MB Studio. Where is this controlled to stop it from doing this. I must have checked something that started that issue.
Thank you!
04 Mai 2017 00:54 #82479 par MB RADIO
Réponse de MB RADIO sur le sujet Wave files being generated using text to speech
You cannot stop it. MB STUDIO need to create the speech file for playing it. But don't worry it is not going to create a new file undefinitely. It will overwrite the same file for the same voice so it's not going to fill up your hard drive
  • paul03034
06 Mai 2017 00:16 #82508 par paul03034
Réponse de paul03034 sur le sujet Wave files being generated using text to speech
I just check and it is writing file after file and I have attached picture of folder full. I just counted almost 200 since yesterday evening.
Thank you!
06 Mai 2017 12:07 #82512 par MB RADIO
yes you're right ...something gone wrong on that version. Please update to 8.59.0.7 version and this should be fixed.
Les utilisateur(s) suivant ont remercié: paul03034
Temps de génération de la page : 0.039 secondes
