Bad rotation
01 Mai 2017 11:03 #82436 par radiop
Bad rotation a été créé par radiop
Good morning, I've been using Mbstudio for a few years and I still have the same problem. From version to version I wait until the problem is solved and nothing so far. Mbstudio is an excellent program but in the rotation of the songs it leaves much to be desired, I have already tried everything, the configurations that are in the site, given by the company by users, with many musics and continues to have bad rotation ie, The same singers. Can someone help me with the best configuration? Thank you.
  • roberto
01 Mai 2017 12:39 #82437 par roberto
Réponse de roberto sur le sujet Bad rotation
mbstudio version?
01 Mai 2017 12:49 #82438 par radiop
Réponse de radiop sur le sujet Bad rotation
New
01 Mai 2017 12:50 #82439 par radiop
New and last
01 Mai 2017 13:00 #82441 par MB RADIO
Réponse de MB RADIO sur le sujet Bad rotation
The music rotation is jolly good in MB STUDIO, probably there is something wrong in your setup. Please select menu Help\Send Debug ro MB SOFT and i'll tell you how to fix the problem. By forum i cannot help because i don't see your setup, songs, playlists, etc etc .
01 Mai 2017 14:10 #82444 par radiop
I could send you the report but I have changed several times to see if I could get the best rotation. You can send me the best configuration to pass the tracks all of a genre and not to repeat at the same times. If it is passing through pulp, the rotation is better?
01 Mai 2017 14:32 - 01 Mai 2017 14:34 #82445 par MB RADIO
Send the debug anyway ...i'll take a look and i will suggest you what to change for best performance
Generally speaking the best setup is to not set anything in the songs properties (distance 0) and set only the global distance in Setup\Songs ... but i cannot say exactly without see your parameters
  • paul03034
06 Mai 2017 00:38 - 06 Mai 2017 00:41 #82510 par paul03034
Réponse de paul03034 sur le sujet Bad rotation
Mine works fine and I attached my configuration. I do not set each song individual. I use setting in setup.
See picture.
I have not had repeat issues that I have noticed.
I use one hour for DCMA reasons. If you want song not to repeat increase from 1 hour to whatever max is allowed that you like.
If you don't have many songs, the rule cannot apply and it will have to repeat same song even though you say never repeat less than x hours.
