Velleman evolution and playlist
  • cyberfun
19 Jui 2015 16:47 #77921 par cyberfun
Velleman evolution and playlist a été créé par cyberfun
Hello,
Does the new version it might be helpful to integrate an order with Arduino parallel to the Arduino velleman because it does not need external power and is much more flexible with respect to the interface velleman . a palette and jingles all the MB command in a single block with Arduino would be welcome. the use of velleman is intuitive but not asser flexible dimension configuration.
at the same time another question. It would be nice to set an independent software development which is based on the database of songs for automatic playlist generation for issuance voicetrack. it could exploit the database and auto-generate the playlist according to the hours that you need.
thank you
ps: desolé for my english google is my friend for life ;) ...
20 Jui 2015 07:23 #77922 par alvin
Réponse de alvin sur le sujet Velleman evolution and playlist
Next version is screen adaptable and it has disangaged windows for jingle palette. It means that you can move the palette windows in a second touch monitor and use a palette ;)
I already know that this year MBSTUDIO will be used with other music scheduling softwares :)
Temps de génération de la page : 0.044 secondes
