Problem Quality MP3 128 with MBRECASTER PRO
  • vsradiofr
25 Mar 2015 11:20 #77171 par vsradiofr
Problem Quality MP3 128 with MBRECASTER PRO a été créé par vsradiofr
Hello everyone, I am using the MBRECASTER PRO software, I love it, however this software there's one thing I do not like.
Let me explain, I diffuse my internet radio mp3 128kbps with my old software quality was very good, knowing that I use behind its processing equipment .. today PRO MBRECASTER if I diffuse in the 128 mp3 sound is very metallic, if I increase the quality mp3 192 is better, but that is not equivalent to mp3 192 kbps other software, so I asked a question there 't' there a codec issue with mbrecaster pro? is it possible to replace the codec if it is the case? thank you in advance for your help.
25 Mar 2015 13:48 #77172 par MB RADIO
Réponse de MB RADIO sur le sujet Problem Quality MP3 128 with MBRECASTER PRO
The MB RECASTER PRO software use the standard lame MP3 codec so it should be pretty the same with all others software using lame.
You can also use a different codec if you like: i mean the ACM codecs that must be installed in Windows.
www.rarewares.org/mp3-lame-dshow-acm.php
Once you installed that codecs restart MB RECASTER PRO and choose thhis codec:
Let me know if you remark any difference in the sound quality
