MBSPOT PROBLEM
02 Mar 2015 17:24 #76828 par radiop
MBSPOT PROBLEM a été créé par radiop
Good afternoon,
Realized this morning MBSTUDIO update to version 8.55.7.
From that moment I got a problem in MBSPOT, left blocks to enter at all times, in the time signal in the function 16h ace finished it just does not respond or part blocks. I made some changes unknown?
Thank U.
02 Mar 2015 18:32 #76831 par MB RADIO
Réponse de MB RADIO sur le sujet MBSPOT PROBLEM
Please select menu Help / Send debug to MB SOFT and i'll take a look
02 Mar 2015 19:11 #76832 par MB RADIO
Open MB SPOT, select menu "Lista de Blocos" and "Restaurar Base de Dados". Open the folder "Domingo" and select "Sequences0.dat"
02 Mar 2015 20:01 #76835 par radiop
Réponse de radiop sur le sujet MBSPOT PROBLEM
The problem keeps!
02 Mar 2015 20:02 #76836 par radiop
The problem just keeps the block early. The rest are good.
02 Mar 2015 20:18 #76837 par MB RADIO
Select menu Help \ A ligar MB SOFT and send me the ID number by private message. I'll connect your computer and fix the problem
03 Mar 2015 17:40 #76851 par radiop
Despite the technical assistance of this morning, the problem continues and has not been resolved. Thank you
03 Mar 2015 20:20 #76855 par MB RADIO
I fixed the problem. Redownload and reinstall the file: www.mbradio.it/en/download-en/customers-...StudioInstall855.exe
03 Mar 2015 20:36 #76856 par radiop
problem solved. Thank you very much!
03 Mar 2015 22:33 #76859 par Medeiros
Réponse de Medeiros sur le sujet MBSPOT PROBLEM
Here also resolved.
Thank you :cheer:
04 Mar 2015 12:14 #76868 par radiop
