Rotatividade 2
30 Nov 2014 17:52 #75870 par radiop
Rotatividade 2 a été créé par radiop
Good afternoon,
I am from Portugal.
I already have some years MBSTUDIO PRO is a fantastic software.
Just have a problem I can not solve in any way, I saw here in the forum there are radios with the same problem.
In terms of turnover the MBSTUDIO failure, that is very repeats the songs.
Even with many songs he plays many repeated and often at the same times. In radio terms is a serious problem because it gets very repetitive.
I wish I had help.
Thank you
30 Nov 2014 17:59 #75872 par MB RADIO
Réponse de MB RADIO sur le sujet Re:Rotatividade 2
Which version of MB STUDIO are you using?
30 Nov 2014 19:21 #75873 par radiop
Réponse de radiop sur le sujet Re:Rotatividade 2
  8.55.3
30 Nov 2014 21:24 #75876 par MB RADIO
I'm aware there is a problem that will be fixed in the upcoming update
30 Nov 2014 21:32 #75878 par radiop
Would that help me to how best "general configuration in music" MBSTUDIO and how best rotation only in each of the songs?
Thank you very much.
30 Nov 2014 22:18 #75879 par MB RADIO
You can start with this setup\songs:
Distance among same Artist 2 hours
Distance among same Title 0 hours
Distance among same Album 0 hours
Distance among same Hitlist 1 hour
do not set custom setup on the songs and let MB STUDIO to freely rotate it.
30 Nov 2014 22:21 #75880 par radiop
Thank you very much!!!
  • greatwindowsss
17 Jan 2015 05:55 #76217 par greatwindowsss
Réponse de greatwindowsss sur le sujet Rotatividade 2
My question is very simply, how to change the english language to spanish?
Thanks!
17 Jan 2015 14:41 #76218 par MB RADIO
Réponse de MB RADIO sur le sujet Rotatividade 2
Normally it display the same language of your Windows operating system.
However if you want to force a different language, explore the subfolder Language, rename English.lng to something else, and rename Spanish.lng to english.lng and restart the application.
