MBSpot sequence
27 Nov 2012 20:47 - 27 Nov 2012 21:07 #67194 par Medeiros
MBSpot sequence a été créé par Medeiros
Maurizio which the possibility of placing a "Stand by the end of the audio" in MB SPOT?
So put the playlist and waiting for the end of the audio being transmitted.
This spoken on the subject here: www.mbradio.it/public/forum/index.php/topic,12135.0.html
In order to do updates MB Studio 8.53...
28 Nov 2012 21:12 #67226 par Medeiros
Réponse de Medeiros sur le sujet Re: MBSpot sequence
Maurizio is it possible?
28 Nov 2012 22:08 #67229 par MB RADIO
Réponse de MB RADIO sur le sujet Re: MBSpot sequence
at the moment it's not possible because other customers want the break to finish at exact time ... i'll see what i can do in the future
29 Nov 2012 00:34 #67232 par Medeiros
The option was to have the two solutions. I hope it's soon. Thanks Maurizio
01 Fév 2015 19:28 - 01 Fév 2015 19:28 #76426 par Medeiros
Solution already exists (MB Studio 8.55.5 / Future)?
01 Fév 2015 20:22 #76430 par MB RADIO
No, sorry. Not available.
02 Fév 2015 10:48 #76437 par Medeiros
And in next update?
19 Fév 2015 18:03 - 19 Fév 2015 18:04 #76619 par Medeiros
I need this function to be able to continue working with the MBStudio.
They also need to update the new functions.
We are still working with version 8:50.
Tanks Maurizio
19 Fév 2015 18:26 #76620 par MB RADIO
Which functions are you meaning?
19 Fév 2015 18:58 - 19 Fév 2015 19:05 #76624 par Medeiros
The only function that is missing is that I speak here in this topic.
For us it is very important. We wanted to use the latest version of MBStudio in order to take advantage of other features of the software.
19 Fév 2015 19:33 #76629 par MB RADIO
your request was already answered in the old forum:
There was a bug in the older version so the sequence was not cutting and not finishing at the expected time, so users complained about sequence not finishing at expected time.
If the the block may exceed 15:00:00 don't use that option. If the block has a duration of 2 minutes simply change the time to 14:58:00 (without using any option) and you'll get what you need.
this is the solution for you, there is no need to wait for any change
19 Fév 2015 20:00 #76634 par Medeiros
But not the block has a certain time because it depends on the number of spots included in the block. You can have as 2:25 1:32 ...
It will will always put in the playlist block at that time without cutting what is in the air?
