MB LIVE periferique
18 Juil 2011 18:12 #58022 par
MB LIVE periferique a été créé par
Hi,
I use MB LIVE 1.46 on a PC with XP SP2, connection and use is OK on the PC with MB STUDIO 8.46 which means MBSTUDIO configuration seems good. But now I have a new PC on WINDOWS 7 64b, I can install MB LIVE 8.46, software is running but periferique area is empty, no sound card detected ? I have tried with another PC on WIN 7 64b and the same result. Please why ?
When I try the button CONNECT, connection start but stop immediately with a message error "absence de son en entrée".
18 Juil 2011 18:15 #58024 par MB RADIO
Réponse de MB RADIO sur le sujet Re: MB LIVE periferique
In MBLive\Debug folder there is Monday file...please send it to see your configuration.
18 Juil 2011 18:34 #58025 par
Réponse de sur le sujet Re: MB LIVE periferique
File is on the mail
18 Juil 2011 18:34 #58026 par MB RADIO
According to debug file there are no capture WDM audio cards available in the system.
Please check this window if there are audio cards available.
19 Juil 2011 07:50 #58042 par
Yes there is an integrated audio card on the mother card. This is a PACKARD BELL
19 Juil 2011 10:23 #58048 par MB RADIO
As you see there is nothing connected, "Non connecté".
In windows 7 and Vista, some cards only work when you phisically attach a plug to the input. So, first connect a cable to the jack input, after run MB LIVE and you'll get the program to work.
19 Juil 2011 18:53 #58071 par
You're. It's OK now with a cable connected on the audio card.
Thank you very much. I didn't know this approach !!
See you
