Freeze Problem
24 Mar 2011 15:18 #55255 par
Freeze Problem a été créé par
Hi Maurizio and all people, two nights ago that the program remains frozen during the late night, which may be happening? the computer has no faults, but the program remains frozen. any suggestions?
MB Studio 8.45 version, spanish
Sound Card EMU 1212m
thanks!
24 Mar 2011 18:01 #55258 par MB RADIO
Réponse de MB RADIO sur le sujet Re: Freeze Problem
Please use menu Help \ Send debug to MB SOFT to investigate your problem
24 Mar 2011 18:52 #55262 par
Réponse de sur le sujet Re: Freeze Problem
I do, but still in sending data...loading...
this proccess can take a few minutes?
tell me if you recieve the debug.
Fabian
24 Mar 2011 18:56 #55263 par MB RADIO
Usually it's not so long .... please do not put audio files into MBStudio\Folders, especially in Sequences, Playlist, Debug folders ... if there are audio files, please remove it.
24 Mar 2011 19:20 #55264 par MB RADIO
Update to 8.46 version.
If you still have the freeze problem send the debug again.
29 Mar 2011 14:47 #55403 par
This is the error.
09:17:33    BASS_ACTIVE_STOPPED Handle:-1342177242
09:17:33    Error on liberarisorseoggetto Access-Violation - 3
09:17:33    ======================================================================
29 Mar 2011 15:52 #55404 par MB RADIO
Could you please send me this file:
D:\MUSICA-AIRE\MUSICA RADIO\Jet - Move on.mp3
29 Mar 2011 23:23 #55416 par
ok. the track have a big silence end.
www.megaupload.com/?d=STQJ2MJ0
01 Avr 2011 23:05 #55511 par
hey maurizio! anything new about my problem?  :(
02 Avr 2011 00:06 #55514 par MB RADIO
Yes, that file is corrupted and cause MB STUDIO to crash. Probably you have also other files corrupted. There will be a fix available in few days.
