MBSpot GLOBALY
10 Oct 2008 23:40 #32477 par
MBSpot GLOBALY a été créé par
Hello everyone !!!
I'm from Serbia & I dont speak italan unfortinatly...my english is very bad to  :(
I'm working 15 years like technical man on broadcasting radio & we try a fiew automation radio software like zara,raduga,jazler.....
I like this software at first sight - interface,streaming,sms,agc itc.....,but before we by this software i have some question!!!!!!
Evrything about player it's ok perfectly clear but my question is about spot:
1.Do must they play at  00:00,00:15,00:30,00:45...or they can move to another time
    (my client's want's to play he's comercials at : 00:10,00:20,00:35 etc.
2. Second question is abot spot filter/print.......my client's or director or man who works on workstation like comercial administrator want's to see
    every spot or block or sponsor played from 18.08.2008 to 20.09.2008
    -  filter for out date spot
    -  filter for programmed spot or block from date to date
    I know that I can see more in .log file but I need direct filter without editing from another software
3. Can I use any-way MB datafor external schedulig software like Powergold or other scheduling software & use external sheduling data in MB soft.
4. Unfortinatly we work with touch screen did MB Soft planning in next ver. integrateted support for this technology?
Thanks & sorry for my bad english :)
12 Oct 2008 15:49 #32501 par MB RADIO
Réponse de MB RADIO sur le sujet Re: MBSpot GLOBALY
You're welcome.
You can create breaks at any time clock. When you run MB SPOT, on the first screen you have the buttons to create a new break, modify existing breaks time, or delete it.
this is available. when you run MB SPOT click on the 3rd tab ("Customers List"), here you have to add your commercial files and a specific customer window will appear when you double click it on the list. Here you can click the "Report" button and choose the date range to print out.
At present, MB STUDIO can only import external .m3u playlists. However i cannot exclude in the future more interfaces with other softwares.
As far as i know, there is no need to special support from an application. Do you have some specific problem with it?
12 Oct 2008 22:21 #32509 par
Réponse de sur le sujet Re: MBSpot GLOBALY
Thank's for unswer Maurizio  :)
Now  I'm complettly satisfied for possibility MB soft. & I hope that we by this software this month!
PS:
Question about touch screen is for the interface(size of button),well you know that many automation software like your MB have BIG button for easier finger manipulation ......
Salute :)
12 Oct 2008 23:52 #32510 par MB RADIO
Currently MB STUDIO is optimized for 1024x768 screens, however in 2009 there will be an update that will especially support big screens (1280x1024 resolution) with bigger buttons and fonts.
13 Oct 2008 12:36 #32527 par
Dear Maurizio,
We have some more questions:
It's very important for us to work with remote access and remote administration, first of all remote administration of MB Spot (breaks and commercials).
Is there possibility of creating more user accounts, with variable level of administration and usage of this software.
MB STUDIO still can't manage more than 128 folders?
We would like to know something about purchasing (price, technical support, warranty, terms of delivery, etc...)
Kind Regards
13 Oct 2008 15:21 - 13 Oct 2008 15:31 #32535 par MB RADIO
Inside your LAN you can install MB STUDIO/MB SPOT for remote administration on all your computers without additional license fee.
For external network access you have to use VNC.
No, there is only one lock password for unauthorized access.
Usually 128 folders is a huge amount. Tipically commercials are all grouped in few folders.
Take a look here:
www.mbshop.biz/index_l2.php
13 Oct 2008 18:36 #32561 par
Web page for shopping allow only paypal solution for my country (Serbia)
Do you have anny other payment solution or transfer,becouse we are legally business/corporation and we have account !
contact:
marketing@studiom-cacak.com
