The MB STUDIO installation package requires entering a code. This code may change with each MB STUDIO update.
The code is only needed for:
- install MB STUDIO on a new computer
- reinstall MB STUDIO from scratch
- update MB STUDIO from version 8.73 or lower.
If you want to update your MB STUDIO 8.74 or higher, you don't need any code, just follow one of these procedures:
MB STUDIO - CHECK FOR UPDATES or MB STUDIO: AUTOMATIC UPDATES
If you need to install MB STUDIO on a new computer or reinstall MB STUDIO from scratch or update MB STUDIO from version 8.73 or lower you can obtain the installation code by downloading this program and running it:
USB DONGLE PASSWORD
Popular 8.75 1.67 MB 8514 |
17/04/2024 18:10:00 |
This window will be displayed:
ID: it is the serial number of the cryptobox USB key. This number must be communicated to us for any technical or commercial communication and uniquely identifies your license and the purchaser. This ID is also visible from the MBStudio\License menu. The date on which your subscription to updates will end or has ended is indicated next to it.
Below are listed all the versions of MB STUDIO that you can install and the relative installation code.
If the latest version does not appear in the list, it means that your subscription to updates has expired and must therefore be renewed UPDATES - HOW TO UPGRADE / UPDATE MB STUDIO
If you're looking for older versions of MB STUDIO take a look here: https://www.mbradio.it/en/download-en/customers-area?folder=OLD
The installation code can be written down and used to install MB STUDIO on other computers without a USB key.
The USBDonglePassword.exe program must be re-downloaded each time a new password is to be obtained.
Don't forget to turn on automatic updates: MB STUDIO: AUTOMATIC UPDATES
