ESI MAYA44 eX
25/04/2023 21:36 #97893 da Medeiros
ESI MAYA44 eX è stato creato da Medeiros
I'm thinking of buying the ESI MAYA44 eX audio card.
With it I can broadcast and pre-listen at the same time and even use it for setreming.
What kind of cables do I use to connect between it and the mixing console?
25/04/2023 21:59 - 25/04/2023 22:02 #97894 da MB RADIO
Risposta da MB RADIO al topic ESI MAYA44 eX
yes you have 2 stereo outputs and 2 stereo inputs
inputs and outputs are stereo jacks 6"
www.esi-audiotechnik.com/tools/zip.asp?f...MAYA44_eX-PCIe-2.jpg
www.mbradio.it/en/mb-studio/accessories/853-maya44ex-sound-card
Ultima Modifica 25/04/2023 22:02 da MB RADIO.
29/04/2023 17:04 - 29/04/2023 18:23 #97915 da Medeiros
Risposta da Medeiros al topic ESI MAYA44 eX
I bought the audio card and I'm really enjoying it.
I would like to put an external audio source through the input of the audio card (ESI MAYA44 eX).
It would be possible to put it in the External flow module to fetch the audio from that card.
It would capture the satellite signal (audio) and send it directly to MBStudio.
The satellite relay (audio) would be through the monitor board or master board placed in the MBStudio sequence as it is now used the external stream module from other sources.
Ultima Modifica 29/04/2023 18:23 da Medeiros.
05/05/2023 21:09 #97944 da MB RADIO
yes you can use the EXT section of MB STUDIO to capture the inputs of the audio card:
www.mbradio.it/it/supporto/guida/102-con...sorgenti-esterne-ext
06/05/2023 00:24 #97947 da Medeiros
I understood.
And how can I then play that audio in the pre-listening easily by the studio operator.
I can broadcast from MBStudio, but the goal is not to be broadcast from the master audio card, but from the secondary.
I currently capture this signal over the internet in the external stream and open the pre-listening and it plays on the secondary audio card.
06/05/2023 00:40 #97948 da MB RADIO
you can use the live section and choose the input and the output that you want
06/05/2023 13:39 - 06/05/2023 13:44 #97953 da Medeiros
It doesn't look very practical.
Is it not possible to put this in the external flow module?Assigning a name
Examples:
Source: EXT1
Source: EXT2
Ultima Modifica 06/05/2023 13:44 da Medeiros.
06/05/2023 18:34 #97957 da MB RADIO
you can change the names as you like in windows:
06/05/2023 18:41 #97959 da Medeiros
I know we can change the names there, but that's not the problem.
We always have to pre-listen before broadcasting this audio.
This is not practical so I am insisting on the possibility of having this function in the external flow module.
06/05/2023 20:09 #97963 da MB RADIO
you can prelisten from here:
06/05/2023 20:17 #97964 da Medeiros
I know.
But that has to go through the settings and that is not very practical for the one who is doing the broadcast.
I still think that the solution is for the external module to have this function there, but instead of an internet address it was an audio card.
This was my suggestion.
08/05/2023 13:13 #97980 da Medeiros
Here's the example. But instead of streaming having audio cards EXT1, EXT2...
    MeuVdeo1.mp4
Tempo creazione pagina: 0.061 secondi
